Solar house generator I started DIY back in 2000 - My path from Trace to Xantrex (on FLA battery) to XW Pro inverters on Tesla Model S batteries
Did you do
With a
I bought a Greenlee
for $200 but Harbor Freight has cheaper ones
Did you do
With a
I bought a Greenlee
that acutally had a pre-stamped punch out, that would not come out, by the time I realized this, it had deformed. This unit was the first one I bought 4 some years ago and trying to work in that small space was difficult. So yeah, it is ugly.
okay, I might work on that to even it out, while I have it apart
I own the harbor freight kit. I can attest that they work well enough for 5-8 holes, but get dull quickly. Even when new they have some frustrations. The dies get jammed in every and any hole.
But for $25 I can complain all day. If I lost this set, I'd still go buy another kit from Harbor Freight.
Also, I don't think you need to run Xanbus/network cable through conduit. Just put a straight relief/protection from the edge of the hole and run the cable free on the wall with some plastic retention staples or zip ties.
I'm a sucker for a clean install. Can you remove the divider and drill through it? It looks like this screw and maybe one more hold the divider in place.
The divider has a bend in the area that lines up with the knockout, so it might require some Dremel work.
Put a short nipple through the divider and the low voltage side to keep them isolated? You've already got a conduit knock out on the right side just attach the conduit to the wall of the charge controller and let the divider end float.
Hey, thanks for the good suggestions. Good ideas, but I am continuing with the 3/4" conduit. I had loose cat 5s on the prior wall and thought about retentions but still wanted conduit to protect them from damage. Also the daisy chaining made for some weird looking wiring.
Today I got my first box and got it installed on the #1 CC. The red cat 5 goes up to the Gateway, which is on the opposite wall/shelf and the SCP is downstream from that. Looking forward to powering up the SCP for the first time, as only the inverters provide power for the SCP
Notice the 2 pair gray cable. Attaches to the AUX contactor and activates a 12v relay near the ceciling which turns on water heater via a DC/AC Optical relay, when the battery is full - the diversion load subsystem
here looking up towards the ceciling. I will probably just paint the conduits white and help them blend in
Below CC #2 waiting for the 2nd (and 3rd) box to arrive on tuesay
Couple more parts came in today
Got the 1" flex conduit measured and cut between the PDP and CC #1 and #2
4 conductors (6awg) plus a ground to each CC - done it before with 90 elbows, now just straights and curvely conduit
the 2 attached to the PDP will be easy
Here is #1, and the upper Xantrex box buttoned up
Here is the conduit for CC #2, along with the Lower Xantrex box - still open waiting for 3rd box to come tomorrow, allowing more wiring to be installed.
last (white) box came in, and installed it
And cut and fitted the flex conduit for each of the incoming array lines
I little background info
I am using this thread as a Show and Tell, but my main reason is, it is a vlog of my build thread where I log pertainent information on what, why, and how I did things. It serves as my long term memory. I also save this pages locally so that I have a backup in case we lose this web site, heaven forbid
I was able to accomplish re-attachment of the Charge Controller #1 which manages array #1, obviously
here is the series of pics of the wires coming in from the arrays, through the PDP and into the CC
Entry of the array feedlines enters this box, a re-purposed service panel, on its side
Each array has a relay/contactor which can interrupt incoming current. The controller that does is the EVTV V2 Controller - Jack-In-The-Box ->> https://store.evtv.me/products/esp32bms that is between the battery and the bus bars, and thus the inverter
This "jack-in-the-back" or JITB, monitors several attributes of the environment and the battery. If anything falls outside of (settable) parameters, the JITB shuts the entire battery system DOWN hard - it turns it off. One of the things that is shutdown down are the incoming charging streams from the arrays. It does this by operating a signal, which is called CHARGENABLE. Normally OPEN, when things are within parameters, it signals a CLOSE control, which I have wired to a normal 12v relay. When enabledl, it causes these 4 contactors to close, thus allowing charging current to enter into the system. If something is amiss this CHARGENABLE is disabled and the contactors OPEN. During normal operating conditions, these contactors are closed, allowing current to enter.
In the following pic, Array #1 wires enter the PDP on the left with a ground wire, and POS and NEG wires. This is the only ground wired between the contactor box and the PDP. Below that, I also have wired GRID AC IN to the AC breaker on the left
Following the installation instructions, incoming array POS wire enters the 60 amp DC breaker before being run to the CC. The return wire from the CC then enters the top of the next 80 amp DC breaker
Here a ground, the Array POS (coming from the 60 amp breaker) and the Array NEG enter the conduit to the CC #1. A returning POS and NEG come back the same way
here the incoming and outgoing wires from within the CC, a ground is attached at the back wall. This a difficult small space to set these wires, for sure
this the bottom of the 60/80 amp pair of breakers for CC #1
on the left is the exit wire from the 60 amp, that goes to the CC, and the next one to the right is the exit wire from the 80 amp breaker. This one then goes to the common POS battery bus bar, coming up next
I saw the PV contactors label in the previous post and was hoping you'd show more on those.
What's the point? The charge controllers can stop PV and the BMS can stop current at the battery, right?
Here is the main POS bus bar within the PDP. I have not yet attached the 4/0 battery lead.
This particular bus bar is the standard one that comes with the PDP. It has space for two 250amp breakers (one installed on the upper right, that open hole can be used for the 2nd 250amp breaker.
This has only 3 lugs for incoming arrays. I have 4, so I used the 4/0 attachment point on the left for one of my arrays. When one buys the upgrade for adding more inverters (to 2 or to 3), a new bus bar is in the package. It has room for 2 4/0 cable attachment and 4 incoming array lugs and 3 mount holes for 3 250 amp breakers.
The output from each of the 4 80 amp breakers comes here and is attached
here is the NEG bus bar plate
Here is CC #1 finished and buttoned up, ready to go
Behind CC #1 is a recessed area for the main POS and NEG bus bars. Here the NEG bus bar has a 400 amp fuse on the incoming lead from the JITB (2/0 cable)
Exiting the bus bar the cable enters the current shunt from my prior configuration. This runs a meter up in the kitchen for quick observation of charging/discharging, etc
and finally the Xanbus goes up to the ceciling to the opposing watt (where some of our pantry is) and connects to the retired product Conext Gateway (replaced with the Conext InsightHome). It then connects to the also retired product, Conext SCP. The SCP allow for panel configuration without the need for a computer and browser. I got these before they retired the products
An interesting point I found, was that the SCP is ONLY powered by an inverter over the Xanbus. The CC are powered by their battery. Because of this I have not used the SCP at all. It has just been in a box for the past 3 years
Now to wire up the CC 2, 3 and 4
The instructions state to mount the inverter first, then the PDP, but I decided to mount and attach the PDP and ready what I can awaiting for the inverter. BTW, the inverter shipped yesterday - finally
The JITB has no communications with the charge controllers. When the JITB detects an out of bounds issue, it can disconnect the batteries yes, but the CCs will continue to pump current with no batteries to send it to, not good for the CC
Also Jack Rickard who designed the JITB, had other configurations where this type of control proved of benefit. He had 5 5kw SolarEdge string inverters with 27kw of panels coming into his shop. 15kw inverter, 100 kwh of tesla batteries. He wanted to STOP everthing down, when the JITB detects an issue
Jack was any interesting guy.
He had cash flow. Back in 1997 or so, he installed a PV whole house generator and it cost him $275,000 for the joy of it.
he was into EVs for some time, then switch to solar
his youtube link https://www.youtube.com/@EVTVMotors
Are those round black cylinders the relays switching PV strings? Do the voltage ratings support it?
In your interlocked transfer switch breaker panel, interesting lugs/busbars to bridge every other breaker terminal. I assume those have 240VAC between them. I suggest some kind of insulation between and over them.
Oh yeah
Gigavac GX1BB 150amp, 12-800vdc, $110 back in 2020
coil is 12vdc
I have pondered that same thing, but it is UL Certified
keep the fingers out
The PDP and the 4 CCs are mounted and wired, save for the actual inverter
starting at the bottom
DavidPoz made a good point of the weight of the 4/0 cable hanging by the bottom bolt of the 250amp breaker, placing strain on it. He came up with a good strain relief solution, which I also followed below
Here are his words on this issue
Below is the pic of that rubber gripper on the NEG 4/0. I installed the same on the POS. And it really provides a good strain relief
Notice I have installed 7" of 2.5 inch conduit over the main 2.0 inch conduit. It slides up and down and will provide protection to the upper part of the cable when in the up position. I cut 4 slots in the bottom the 2.5 inch to allow for a clamp to be tightened and lock the slider into place
another pic
looking up at the PDP fully wired and the contactor box
upper distribution portion. I have turned on the battery (breaker to injverter off though ) and voltages measure good for battery and charge controllers at various points
you might notice I am missing one of the AC breakers, namely a 60 amp for CC #4
Seems last time I installed the system, I stripped the lower wire mount point, so it no longer works after being removed. Ordered a new one ($54) from Signature Solar and will install when it gets here
Lower portion of PDP
Pic from the right of what is there
more pics of the finished PDP
Xantrex routing box
Left view of the PDP and CCs
with wires hanging out to the left, waiting for the inverter to show up and fling itself at the wall
DEFINITELY looks better and utilizes the space far, far better than the zoo I had before. Well, I didn't have the money back then. Now I do. Correction. I did have the money - now Signature Solar has those dollars
Tired, but feel good about the past week's work to get to this point
Solar will charge the battery tomorrow
couple of things left to do
1) Install inverter after it gets here
2) Install that 60 amp breaker after it gets here
3) Upgrade L1 and Neutral to 4 AWG between PDP and transfer switch (done)
4) Upgrade Neutral to 4 AWG between transfer switch and service panel (done)
Now 4 AWG between PDP and Service Panel for future 2nd inverter use, don't have to play with it later
BEFORE
AFTER with covers back on
Picked up 2 3" clamps and installed on the conduits, so those are set now
Some work on the AC side of things as well:
Finished upgrading L1, L2 and Neutral from 6 AWG to 4 AWG between the PDP, the transfer switch and the service panel. Planning for future 2nd inverter installation someday
and installed the left front panel of the raceway, so all things buttoned up
Did receive 10' of Romex 6/3 for wiring the service panel above to the kitchen's range/oven. Will be adding the 240 v recepticle shortly
Fedex delievery of the XW Pro is scheduled for Wednesday 23, Noon to 4PM
You and your son better start eating your wheaties now ?.
Best wishes for an uneventful XW move from the driveway to the powerwall.
That would be a wonderful Thanksgiving if it all goes well.
