Ordered battery #8. Once it arrives, I will balance the 2 modules so I can place them in series, then manage them and the rest of the pack to a common voltage, then finally install the 2 new modules
Total storage will be 40kwh! (more in the future)
Thought to share my current cost outlay up to this point. I have not included the wiring and conduit of Phase 1 (2000 time frame), nor the mounting brackets of Array 1. This cost is what I have now spent for Phase 2. That includes all new panels, new inverter, new charge controllers, new batteries and wiring of Array 3 and Array 4. (Wiring for Array 1 put in 2000, Array 2 put in 2016 not counted here)
Total: $27,200
For:
40wkh of storage
EVTV battery controller on Tesla batteries to ensure safe charging and operation within environmental limits
7260 watts on 4 arrays.
- Max wattage possible is 4 controllers able to support 3400 watts each, 13,200 watts.
- Realistic max will in the 10,500 to 11,000 watts due to space to put panels
5500 watt inverter on 48v batteries
4 charge controllers and ingress and egress breakers for the same
4 disconnects for the arrays,
4 Midnite solar surge suppressors
4 Contactors controlled by the EVTV battery controller to disconnect arrays for error conditions
Result: 97% off-grid for the nearly past 2 months, after battery modules #7 and #8 are installed that should up that percentage
Monthly production in the 700-800 kwh range (I have computers on all the time)
daily production average is 28kwh, with peaks of 42kwh during high load consumption (ie wash day once a week)
AND water heating as a diversion load, 2 50 gallon tanks, after battery is full
Still un-tapped energy loss due to under utilized PV generation and system loads not being on - no where to use it = yet
Summer room AC and house cooling fans will be on as the temps reach above 90F in the summer
