So I just replaced my SPF 5000 ES unit with a new SPF 6000 ES plus. The issue is the 6000 es is reading a load on the output LCD of 12% with just the auto transformer connected and with all load panel breakers off. I am measuring 120 vac from neutral to ground so this is where the issue is. Does anybody know how to rectify this problem as my 5000 es plus worked perfectly. I am unsure as to whether the 6000 es plus requires a bonding screw to be removed. I have asked Growatt technical support about this but they have not replied.
Any help would be appreciated as I am offline now until I get this sorted out.
Thank you. Ben
Thank you. Ben
