bruno_cmenezes
- Jul 15, 2022
- 6
I'm experiencing this inconvenient situation with an offgrid system that comprises four inverters of the model SPF3000TL LVM-ES in a split-phase configuration. The AC input is a 40kW diesel generator and there are 32 lead-acid 220Ah batteries to supply the loads (8 groups of 4 batteries in series). The system supplies the loads in 2 phases (220V/127V), which means that each phase is connected in two inverters.
The problem is that the generator is never able to charge the batteries when it starts. The two settable programs that are related to the generator functioning are the program 12 and the 13 in the installation manual, as it follows:
Sometimes, at night, when there is a more intensive use of the loads and the batteries voltage drops to the value set in program 12 (48 V), the inverter closes the dry contact connected to the generator, making the generator start. As soon as it starts, the voltage increases again to something around 50V, which is a natural behavior since the current flows in the opposite direction. What is curious is that the inverter opens the dry contact (turns off the utility) again without the batteries being able to reach the voltage set in program 13 (54V), and, as a consequence, it does not charge batteries at all, causing the system to drop the voltage once more below 48V, bringing back the utility again. In my understanding, the program 13 is not working in any circunstance, i do not know if it is a algorithm problem or a setting problem.
The picture below shows this behavior:
Does anyone know how i can fix this?
