meetyg
- Jun 4, 2021
- 1,093
Hi.
I have a no-name MPPT micro inverter that is suppose to handle up to 600w.
But, it has 2 inputs and each is limited to 300w by the specs.
I have a 455w panel, which is too much for a single input.
I can confirm that actual open voltage is around 45v and open circuit current is at or above 10a (it actually blew my multimeter's 10a fuse). So it's really putting out that wattage.
I thought of splitting the output of the panel into two branches (using a Y connector, but backwards) and then connect each branch to to each of the micro-inverter's inputs.
In theory that should split the wattage into two, but my question is does the voltage get split into two or does the amperage?
This is important because the inverter has a minimum of around 20v for it to start working. If a bit less sunny, or a bit shaded (or hot) I guess the panel voltage could drop even below 40v, which would make the inverter refusing to start MPPT tracking.
Thanks in advance.
Thanks in advance.
