jorvelazquez3
Hello everyone, I have a SRNE HF2433u80-H 120v, bought from ali express. I have been trying to get information but so far its been a bit hard. I have several questions and hope someone on the forum could maybe share some light.
This inverter will only charge the battery if the switch for the inverter is on the On position, is this normal?
While connected to the AC In, it still wont charge the batteries unless the inverter switch is on the On position, again is this normal?
What should be the proper settings for this unit?
I suspect there is something wrong with this unit, so trying to rule this out.
The android app smartess for this unit shows only battery usage, PV only shows 0% which is very odd..
The unit is set to charge with utility / main at the moment been trying to get a proper setting to work, but so far nothing unless the inverter switch is on the On position
I also have a PowMr which is basically a twin of this unit minus colors, and it does charge with the switch on the Off position... are SRNE always needed to put on the ON ?
This is backed by 6 430 panels, wired in series as this unity max Voc is at 500v, and minimum is around 125v if remember correctly.
