looknow12
I am running a 12 volt Multiplus II 3000 for an RV and while the AC Load center is completely energized while boondocking. One thing I'm hoping to make more efficient is the Starlink Gen 2 I have running. Yaosheng makes a 48 volt POE Injector https://a.co/d/3PHH4iK and an adapter https://a.co/d/0ICizG9 that lets you bypass the modem and run everything off 48 volts. I also looked up a step up converter that get me from 12 volts to power the POE Injector. My question is will I save anything in efficiency? Or should I just let the Multiplus II invert. Currently my AC loads are 75 to 85 watts so any savings will be helpful as I'm only running 4 100ah BB batteries. Thank you
