reader2580
- Aug 17, 2022
- 104
I have a Victron Multiplus II 48 volt that is about 45 days old. It does not appear to be producing proper AC voltage. The voltage is 119 volts, but I wonder if the frequency is off. This is used in a motorhome. I have a power supply for my CPAP that is cool when used on generator power, but it gets hot when running on inverter power. Microwave also seems to do strange things on inverter power.
Any ideas here? My Fluke 177 meter does not appear to have a way to test frequency. I have monitored with Victron Connect on a PC and don't see any issues. I have talked to the vendor I bought from and received a little help.
I also have charging issues where the inverter will fault out when charging my SOK 48 volt batteries, but that is a separate issue I have been working with the vendor on. I have not yet built the special communications cable between my Cerbo GX and my SOK batteries.
