I just purchased 3 Ecoflow 400W portable solar panels. I have 16 EVE 105ah in series (48V System) with a 200A BK BMS on it. To charge the batteries I use a a power supply normally that is feed by DC voltage from 12V-53V input and able to provide up to 2000W. Anyway. Since I do not have a solar controller yet, can I use a Buck converter step-down that that i have able to convert from 12-90V to 10-88V 40A 1800W ? will that be a problem? The plan is connect 2 panels in parallel and 1 in series to not pass the 90V since each panel I believe is up to 41V. having that setup will damage the panel? I am planning on buy a Victron Energy SmartSolar MPPT 150V 45A for this setup. So.. The buck converter will work?
