MikeSpeegle
Is there any battery turn off relay besides Blue sea systems, and TE EV200A1ANA. Both of which are not UL Listed. The blue sea systems is marine listed and used by coast guard but nope inspector says must be UL listed. He claims they are out there but says it’s not his job to tell me what.
This is my last try before I run 4/0 through my garage wall and brick to make N actually cutoff.
Please any of you installers know of a 12v or 24v relay. Either powered or magnetic lever that will be UL listed. Or any approach I can use. He absolutely hates DIY
Thank you so much to this group already you have helped me so much I. Making my solar system a reality.
I have SolArk 15k AC coupled Solar Edge System. And 4S4P 16 battery 12.8v 250ah system. Setup to be 51.2v 51.2 kWh system of Marine grade Vestwoods 200 amp BMS battery setup.
Thanks for your consideration,
Mike
Mike
