Hot sand battery charges up
The first commercial, sand-based, high-temperature, heat storage system is now operating in Western Finland.
www.iom3.org
I'm trying to adhere to the KISS principle with this. Otherwise it is not worth doing IMHO.You could also just use an insulated water tank for this, and couple a monoblock heat pump to it to make it more efficient. Sand batteries are great, but you need to have a certain size to really make it worthwhile compared to a water tank. This is especially true if you have 'water based' heating such as underfloor hydronic, or radiators even. Because of the lower temperature delta with the environment compared to 500C sand, your insulation becomes easier as well.
I for one appreciate things explained out to simple terms!I'm trying to adhere to the KISS principle with this. Otherwise it is not worth doing IMHO.
Have you personally used 3”+ river rock with an electric element? That just seems very unwise…A simple system would be a metal tank filled with 3"-5" round river rocks heated internally with electric resistance heat elements powered directly from PV panels. No active control would be necessary if the power input somewhat matches the heat extracted. The easiest way to extract heat would be to blow air into the bottom of the tank and extract hot air from the top. If the tank is well insulated temperatures inside the tank could easily reach 1,000F. That said, the tank must be well sealed because any water inside the tank would instantly flash into steam and could result in a massive explosion. A properly sealed tank with adequate emergency pressure relief even with very high internal temperature would be safe to operate as long as no liquid is allowed to enter. The high differential temperature and high specific gravity of rock well compensates for the low specific heat of the rock so very large quantities of heat can potentially be stored.
Typically tank heating elements are enclosed in stainless steel pipes with external flanged ends placed horizontal thru the tank. The element is isolated from the pipe, the element heats the pipe internally and the element is fully serviceable. In this case the rocks would be heated by direct contact, convection, and radiant heat. Air would distribute thru-out the tank. The mostly round shape of suitably sized river rock would provide adequate space for high volumes of air flow with minimal backpressure. Rocks can contain water but if initially heated slowly few will be damaged even at 1,000F. Once dry, no problem.Have you personally used 3”+ river rock with an electric element? That just seems very unwise…
Sand is difficult enough to remain in contact with an element enough to prevent element failure… rock that large seems impossible to do so.
Also… river rock when heated kinda explodes… so…
What would be the best way to heat the sand using solar - heat resistive wires dispersed throughout the storage container?
I have been testing this by using a hot water heater combined with pex pipe to + pump to heat the sand. It is much better to use a restive coil combined with a solar panels..... I switched over to using the solar panels direct to my hot water heater coil, now I have free hot water via the sun and solar panels. That said I am also looking to improve my sand thermal mass project...Just throwing this out there, so don't roast me please..
How about heating the sand directly with the sun? One tricky part on my design would be back filling the section above ground. Maybe some portland cement mixed with your black sand to shape it at the collector? Maybe a reflector of some sort gathering and directing more energy?
If it were me, I would follow polarnightenergy's lead and bury 6 inch stove pipe in the sand and recirculate air.
Again, just throwing this out there..
Your setup uses PV and water, and saying your testing directly heating the sand with the sun like in my drawing is a stretch. If I had a backhoe, I have plenty of clear unobstructed sun and I wouldn't need to dig as much as for a geothermal loop. My guess, about 1/4 of the excavating..I have been testing this by using a hot water heater combined with pex pipe to + pump to heat the sand. It is much better to use a restive coil combined with a solar panels..... I switched over to using the solar panels direct to my hot water heater coil, now I have free hot water via the sun and solar panels. That said I am also looking to improve my sand thermal mass project...
From the air heating collectors Ive seen on youtube reaching 300 °F, the black sand should easily reach 300 °F directly behind the glazing, but how far down this heat would travel is a guess. Many passive solar homes with large southerly facing glazing have insulated curtains to retain heat when the sun isn't shinning, or you need to open and close windows etc. You could cover my sand heater glazing's at night too, or have it automated. This would be a attempt to retain heat until the sun was out again.. Not months.
Exactly why I think river rocks (round) with air circulation as the heat transfer and as heat extraction medium makes the most sense.I agree I am not heating the sand as you suggest. The problem with your suggestion is that dry sand is an insulator It may heat the first few inches like on a beach but unless you had good insulation the heat would be loss. Both of our methods use the sun... I do agree yoru method is different. Perhaps to test your method one could fill a Sun Oven solar cooker with sand and see what the results would be.
Sand on a beach or uninsulated will lose its heat to the earth fast. I read someone mention "its cool just a few inch's below", well yeah.. Most of the US has soil temperatures about 50 so heat will travel to cold. I don't think there is a larger heat sink, so you cant compare it to sand in a highly insulated vessel. .I agree I am not heating the sand as you suggest. The problem with your suggestion is that dry sand is an insulator It may heat the first few inches like on a beach but unless you had good insulation the heat would be loss. Both of our methods use the sun... I do agree yoru method is different. Perhaps to test your method one could fill a Sun Oven solar cooker with sand and see what the results would be.
The problem with rock bed heat storage is that over time dust, bacteria, fungus and other crap builds up on your rocks, and the circulated air can then become a real health hazard.
This problem also exists with ducted heating and air conditioning, its commonly called "sick building syndrome".
Its usually more economic to demolish and rebuild an older building than to completely strip and replace the entire heating and ventilation ducting system.
I only know personally of one Government funded experimental solar/rock bed heat storage project in a domestic home. A large pit was dug and filled with loose rock below the concrete slab on which the home was built. Hot air from solar collectors was used to heat the rock storage during the day, and at night circulated air air was warmed by the stored heat.
It did not work very well in spring or autumn, and not at all during winter. After about five years (I think it was) people started to come down with various illnesses that were finally traced to bacteria in the air.
Back in the mid 1980's I worked for a State Government department that funded and became involved in many different kinds of alternative energy projects. My job as Technical Officer was doing maintenance and data collection, as well as assisting at the original planning stage.Wow. To bad this situation wasn't well documented to prevent it from happening again. Do you have any more details?
That is certainly an issue at low temperatures. However, in a well insulated tank at high temperatures of say 500F or more no mold or bacteria could survive and if being used for domestic heating any residual solid would easily be filtered out of the tempered final air thru conventional furnace filters prior to discharging into the rooms. Other options would be to just recirculate air thru the tank in a closed loop that has an air x liquid heat exchanger. Or maybe directly to a high temperature Sterling motor to produce useful energy.The problem with rock bed heat storage is that over time dust, bacteria, fungus and other crap builds up on your rocks, and the circulated air can then become a real health hazard.
This problem also exists with ducted heating and airconditioning, its commonly called "sick building syndrome".
