I ve been reading all your messages. Please don't make me laugh soo hard.The point of bricks is 10x delta they can handle. And they stay solid unlike water. Heat exchanger is used to retrieve heat or clever design as with UK storage space heaters.
Let me tell you something from the point of physics. Objects like rocks, stones, bricks and sand are releasing heat much quicker. They are fast thermal conductors.
In orders to store heat, you need poor thermal conductors.
Water is the best thermal storage in the world.
Sand or brick as heat battery will never work.
The heat is lost very quick.
They can take a lot of energy, much higher energy than water. But they are not good at holding heat like water does.
I encourage you to get professional advice or do your own research in trusted engineering websites.
All those guys on the page that are talking about using water, are right.
You see? Science can be tricky when you don't listen.
And I have to agree with the guys that posted a lot of lot of messages about thermal heat storages.
Water is the best thermal storage even if it stores little energy. You increase the volume.
You can use multiple insulated oil drums with pressure valves.
You can use submersible 24v 36v 48v heating elements wired directly to the solar panels. No problem with that. Many people have done it already.
You don't need heavy materials to make a tonn of garbage in your property untill you get old. You can just experiment with clean water and send it to a drainage.
Its soo easy to pump it, to get rid of it, to do any maintenance when needed or just to change your home address.
Please listen to the people. You won't dissasemble your brick heating storage.
There was a post about a village where a company built a giant sand battery to store heat in the summer for 6 months, to heat the homes in the village later in the winter. But it never worked. You can't store high temperatures in any solid object even if is reaching the red point for maximum efficiency. It will never work
You know why? Because there is no such insulator on Earth for our needs to store heating energy over the temperature of boiling water.
Water is key for our life on Earth.
Heat storage, mecanical energy for hydropower, drinking source to keep you hydrated so you can enjoy more science.
Drink water and you can relax, slow down, listen, learn to listen first, because science is very tricky when you think you know a lot from it.
