I was thinking of making aluminum bus bars, but ended up just using the tin-copper ones Docan provided. Supposedly they are rated 230A. My bms is 120, I max out at under 100A.
No heating on test.
The group think talked me into replacing the main +/- lugs with tinned instead of copper. Copper on aluminum is about as bad as you can get.
The problem with aluminum is that it surface-oxidizes very quickly, which creates resistance. And corrodes quickly. It’s horrible in a marine environment.
No heating on test.
