Hello all. I am struggling to justify some basic LiFePO4 charging parameters, and relate them to how to set up my Epever Tracer 2215BN. The Epever has many charge parameters geared toward charging older chemistries. This is very confusing to apply to LiFePO4, and the fact that terminologies and recommendations for charging LiFePO4s are all over the place makes it even more difficult.
Can someone please help with some very fundamental questions?
The tracer needs settings for:
1) Charging limit voltage (is this the same as "bulk"?)
2) Equalize voltage (ok, I get that this is to be turned off with a zero duration setting)
3) Boost voltage (what is this? something else to be zeroed out like equalize?)
4) Float voltage (seems straightforward, no questions here)
Will seems to recommend an Absorption cycle and a Float cycle. Which Epever cycle is "absorption"?
Relion recommends a Constant Current cycle and an absorption cycle. Which Epever cycle is "constant current," and which is "absorption"?
Battle Born's docs seem to have use for the Boost cycle, at 14.6V with a 180 minute duration. How does this square with what Will and Relion recommend?
I have a feeling that the answers are simple, but I'm finding it very confounding. I bought the Epever at Will's recommendation, but am finding it not at all beginner-friendly for LiFePO4s. I'm on a low budget, charging two Miady 16AH batteries in parallel, they seem very promising for my application so far, and I just want to give them the best chance for long-term success.
Anyone?
Thanks, Doug
Anyone?
Thanks, Doug
