Here's what I did. I have eight Rich Solar 200 watt, 24 volt panels. Next year I will replace the rooftop A/C with something more efficient. Once I do that, I can fit two more panels on the roof. I could do it w/o replacing the A/C, but that would make it difficult to walk on the roof.
I ended up using aluminum unistrut, stainless steel sping nuts, and EcoWorthy aluminum tilt mounts. I don't think I'll be tilting panels very often, but it's very nice being able to easily tilt them for maintenance, wiring, etc.
In full sun, I get about 1200 watts out of the 1600 watts.
View attachment 47777View attachment 47778View attachment 47779
I'm using 3 x 400w Trina panels (80"x40")
2 will be flat mount, one tilt.
Using two sets of the 41" Ecoworthy tilt kits for the one tilt panel had to modify them a bit to allow the entire thing to fold up without removing the short support piece.
I will get some of the same aluminum unistrut, spring nuts...GLAD TO FIND THIS POST!. trying to decide on 13/16" or 1-5/8" tall unistrut; either 2-1/8" or 2-15/16" gap between panel frame & RV roof....leaning towards more space to get my hands under.
My thumbknob bolts are under the panel not sticking out as yours as the vertical support also is attached and swings out after removing the thumbbolt and lifting panel.
(Flat mounts will have 2-5/16" clearance using the curved two-piece brackets)
I can get a 34° angle this way. Will have to shift the entire leg for winter angles near 50°.
Also going for 8 curved brackets per panel for my flat mounts, two M6 bolts versus one for each mount to the panel. They are big panels.
I've had the panels up, screwed the 2 piece brackets down, then took it all back off.
I'll install the bottom part of brackets then recoat roof. Then install panels.
