about this submersible...Franklin 1 hp 230v #280108------10 amps max draw...200 ft total wiring from the control box 8-10 ga copper in conduit.QD control box.
I was looking at it so if I wanted to run it off the 6000 XP I would have a plan for the wiring. Now the wire to the pump in the 100ft well is sized well but the wire from the service panel to the QD control box is only a 12/2 Romex. That goes to the pressure switch and the larger well wire starts at the QD control box. I assume there is a capacitor start in that box..???Is that normal in your experience? If I ran a new wire from a new panel over by the 6000 XP then a 12/2 is ok??instead of a 10/2..?
