I'm leaning towards a bad cell. Replacing a single cell, instead of the entire battery, requires a top balance. Do you have the equipment to do that?
However . . . I wouldn't rule out poor connections. Half the voltage issues seen on this forum are due to bad connections. Have you verified that all the fasteners are tight? If you were feeling adventurous I would say to pull the cells out and rearrange them. Mark the cells before you do this so you know the original order. If the voltage issue stays in the same position then we know you either have a bad balance lead connection or perhaps the BMS is bad. If the voltage issue follows the cell then it's safe to say that the cell is the problem.
My usual recommendation is to NOT put LiFePO4 batteries in series. If you had a 24 volt battery with a single BMS would that have worked around this issue? If the source of the problem is indeed a bad connection then the answer is no. If it's a bad cell the answer is also no. If it's a cell that needs a little more balancing than the other cells then the answer is probably.
