freepower2023
I am installing an all in 1 sungold power 6kw inverter...120/220 volt.
Looking in the owners manual I don't see what fuse/circuit breaker I should use.
Nothing is mentioned of the amperage.
I would be connecting it between my house breaker panel and the inverter.
I won't be using grid tie so I only need the breaker to run the charger in the inverter to recharge my battery bank when there isn't enough sunshine.
If anyone out there has the same inverter, what amperage breaker are you using
thanks!
thanks!
