jdcorbitt3
I was relocating my solar array. I had the generator running and the batteries hooked. Normally I shut down all power, but this time I did not. I cut the wires to the PV array between my circuit breaker and the TP6048. It arced, which Ed surprised me as I did not expect power coming from the inverter to the array. Now the only way I can power up the TP6048 display is by running the generator. There is 51V t the battery terminals in the inverter, but I have the BP Fault. Also, when I connect the array, it’s voltage goes to 0v.
I opened the inverter and found 5 fused, 4 small ones and one large Vicfuse VBS1749 450vDC 40 Amp. Those fuses tested good. Am I missing another fuse, or does it sound like welded contactors in an internal relay?
