Mfig07
Looking for recommendations. I am in the process of installing a 10k sungold inverter. This will be installed in the garage next to the main panel. Need help with what gauge wire to use.. my solar panels are 60 feet from the inverter, is 10 gauge wire good. From main panel to inverter and From inverter to sub panel will need wire size as well. Also what cut off breakers and disconnect’s switches will I need.
