Does this look about right for options for using Sunny Island 6048-US with lithium batteries?
When connection to a lithium battery:
1. Update SI firmware that has lithium battery option. Some SI don't list lithium battery in the battery options.
Actual battery options:
1. Buy SMA approved battery. Like the LG RESU10H 9.8kw battery for $6056. = $617/kwh capacity. Very high cost.
2. SOk 100AH Server battery - CAN bus communication works. $1,739 x 5.12KWh = $339/kwh. Plug and play setup. High cost.
3. EG4 server rack battery - no can bus communication, might work, might not. Might have future software to make CAN communication work. Have to play with SI or battery settings to get it to work. $1499 x 5.12kwh = $292/kwh. Better cost, but at a price of no CAN communication.
4. Any other lithium battery and any other BMS - set up as AGM in SI and play with settings. Maybe CAN bus communication (or you write your own code and buy parts to make it work). Take your chances.
5. DIY battery using lithium cells and REC 16S BMS for $600/ 5.12kwh battery. Can also parallel cells and use same BMS in the battery. If you want lots of storage, you need several $600 BMS for each pack. REC BMS will work with SI CAN bus communication, but it costs $600/battery.
Say you want 40kwh of storage. The LG way would cost $24,680 ($617/kwh x 40kwh). SOk would cost $13,560, EG4 $11,680, DIY with 280 ah cells could be less, but depends. Also not easy to tell if the quality of the cells is good or not., etc. The REC BMS could make it cost more than other options.
There is also the question of how many battery packs can be connected in parallel to the SI. EG4 might be limited to 6 packs in parallel. Then you may need multiple parallel battery packs to get the KWH of storage that you want.
Trying to see the best way to go.
