Did you happen to review the manual for it yet?
Page 30 (Page 28 in document):
These are most likely intended for LiFePO4 (same as LFP), which is Lithium Iron Phosphate. It is not near as common to use a Li-Ion or other chemistry in home solar implementations.
But also, whether it supports Li-Ion vs LiFePO4, probably has more to do with what the BMSs are, since that setting for Lithium battery in the Deye settings is probably assuming the BMS comms connection implementation (so the inverter can get SoC from BMS). So this encompasses Deye supported lithium battery modules with comms link enabled (reading SoC % off BMS to control charging).
So the question might be, does the Deye all-in-one support good comms with the Jikong BMS?
Besides that, if you won't be using the default lithium selection (which probably requires the compatible BMS comms link), you would most likely just be using the 'Use Batt V' (without comms link) for your LFP battery, and just set your custom charge profile voltage parameters manually anyways.
Page 31 (Page 29 in document):
Note, that you never want Equalization with LFP, so you would set the voltages for Absorption and Equalization to the same which effectively disables Equalization. Not sure if setting the Equalization Days to 0 might also disable, but just to be safe, set volts the same.
Then you can start out with Will Prowse's sticky on the basic settings for charger stages and inverter cutoff voltages:
12V 4S LiFePO4 Battery w/ BMS: Absorption: 14.5V Float: 13.6V Inverter Cut-off: 10.7V-12V (depending on size of load and voltage drop etc) 24V 8S LiFePO4 Battery w/ BMS Absorption: 29V Float: 27.2V Inverter Cut-off: 21.4V-24V 48V 16S LiFePO4 Battery w/ BMS Absorption: 58V Float: 54.4V...
diysolarforum.com
So I guess you need to figure out if you can get BMS communication to work or not before deciding which direction to take.
