I thought you were doing all 3 sides out of channel-strut, but yes, you could use channel strut. Between the triangles, you can use more strut to run stringers for mounting your panels. You might also want to consider angling a bar (More strut?) from the base of one riser to the top of the riser on the next triangle over. This would give the structure a lot more lateral strength.
Before you start buying stuff, make sure you have figured out how you will clamp onto your panels.
Also, you could look into using 2x4s for the riser and the leaning part. It might be a little cheaper.
Finally..... are you concerned about meeting code? My guess is using channel strut would be plenty strong, but it might not meet code requirements because it is not a 'certified' solution.
You may want to investigate what commercial mount systems are available. I have never used them so I don't know if they are pricey or not but they would more likely meet code and might be easier to set up.
