spacebicuit
Hi - I have 7 x 250w Sanyo panels and a Schuco inverter. I have had to remove them due to a reconfiguration of my loft space. until I can put them back in place I am attempting a temporary installation in my back garden.
I have extended the cable which takes my generation back to the generation meter - so that it extends out to the garden. This cable runs to an isolator switch, which in turns runs to the Inverter and the Inverter runs to another isolator switch which the plus and negative from the panels plug into.
I have tried with a single panel connected - the inverter has the green, amber and red light illuminated - any know what this means?
![IMG_20240720_125713.jpg IMG_20240720_125713.jpg](https://diysolarforum.com/data/attachments/229/229902-0b074e56962714ab2de6184295308151.jpg)
The cables that connect the panels look like this - there is also a sticker with instructions but I'm not quite sure what they mean:
![IMG_20240720_125958.jpg IMG_20240720_125958.jpg](https://diysolarforum.com/data/attachments/229/229903-918b34c378110ec254b0c8647ace4fc4.jpg)
![IMG_20240720_130006.jpg IMG_20240720_130006.jpg](https://diysolarforum.com/data/attachments/229/229904-bab9235065780c63c1ff85925f1849a9.jpg)
Since I have only one panel connected there is only one possible way to connect it so I can't see that I have connected anything incorrectly?
This is the setup - isolate top left run back to my main generation meter.
![IMG_20240720_130020.jpg IMG_20240720_130020.jpg](https://diysolarforum.com/data/attachments/229/229905-3aee8702e3ea03ee5088353faed19b62.jpg)
Do I perhaps need more than one panel to fire the system up? If so and I add another in series how do I know which way around the cables should go?
Thanks in advance!
Thanks in advance!
