Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,977
Those are DC chargers, not AC. Completely different beast. You won't have those at home.
22 kW is about the upper limit for an at home AC charging, using a 3-phase 400 V EVSE. But most EVs can't accept that much AC power anyway, and are typically only able to draw half that or less. The standard range Ford Lightning charges from AC at 11kW max. The LR version can do 19 kW.
Why not?
An off-peak charge will supply more than enough miles in the tank for a day's run from home to supply store to worksite and back home.
But you know what else it does? It can supply AC output at 10 kWh (17 kWh for the long range version). That V2L capability is pretty neat.
It's a 98 kWh battery + 10 kW inverter with a truck attached for $50k.
I like the truck but i like the hybrid version more.
However, we weren't talking about trucks.
We were talking about grid loading.
If everyone changing to electrics isn't going to drastically increase grid load then the vehicles weren't contributing much to C02 output in the first place and spending a shit load of money changing everything over is pointless.
You cannot make both claims I.E.
1) Passenger vehicles contribute a significant portion of C02 emissions.
And,
2) Changing them over to electric won't strain grid and generation sources.
Only 1 of the above can be true. Take your pick.
