Markus_EG4
I am from Germany. Don't mean to come off rude
Wow some of you guys have really been thinking about this for a while. This is a very impressive list. Very detailed ![Love :love: :love:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Add AFCI or if present clearly state that it is in the data sheets and manual.Upgrade the charge controller built into the mini splits. Up the voltage.
I like the sound of that. Can you explain your concept a bit more? Would it us PV panels? Would it use a water heating panel that heats the water directly?@Markus_EG4 How about a solar-electric hot water heat pump? Ideally just a tankless outside unit with a pumped water loop to an indoor tank. Reduces shipping requirements, and I am guessing you could make the controls and integration pretty straightforward. PEX and taps for the inlet and outlet water would make it an easy DIY project.
I don't know where Shimmy was going with it, but I like the idea of a remote mounted DC solar powered Heat pump water heater. Even better would be a hydronic indoor head for their mini splits. That way it could be used to convert a conventional water heater tank to H.P. or used for heat source for hydronic floors.I like the sound of that. Can you explain your concept a bit more? Would it us PV panels? Would it use a water heating panel that heats the water directly?
SANCO2 makes a unit that is similar to what I am thinking, but for solar-friendly I would reduce the compressor size by half (half-ton compressor?), add 1-2 kWh of battery, and an MPPT to support 2-3 ~400W panels. Cheapest solution is to focus on moderate climates, minimum operating temperature around 40F.I like the sound of that. Can you explain your concept a bit more? Would it us PV panels? Would it use a water heating panel that heats the water directly?
The Sol-Ark 15k have integrated breaker on DC and load side.The AIO with built in breakers/panel would really simplify installation for a lot of people.
They are. It’s definitely an issue.Cheaper racking! Dear lord mounting solutions are more expensive than the solar panels they are holding!
