What can one do to prevent someone randomly punching your rapid shutdown button on the side of the house and causing your backup panel to go dark?
Can I put the RSD button inside a NEMA 3 enclosure so it looks like a "normal" electrical thing and then have a security tag like the meters do?
The RSD buttons I can buy don't have that. They are big red things that attract attention and beg people to push them. If there is a security tag, that will keep people out of the box unless they really want to get into it.
Code says:
The rapid shutdown initiation device(s) shall consist of at least one of the following:
Thoughts?
Mike C.
Code says:
- (1)Service disconnecting means
- (2)PV system disconnecting means
- (3)Readily accessible switch that plainly indicates whether it is in the “off” or “on” position
Thoughts?
Mike C.
