Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
YW-3.2V-280AH, YW-3.2V-280AH direct from Shenzhen Luyuan Technology Co., Ltd. in CN (alibaba.com) <--- Amy Wan's company, formerly of XUBA.
This price point WILL NOT LAST, the remaining 600 or so will sell at this price, the next batch is more $ (for everyone).
The Slab also has PEX in it for Solar Radiant Heating provision. Was intending to install a Solar Heating system based on the projects here: Solar Water Heating Projects and Plans (builditsolar.com) It does work up here if you do it right.
My Powerhouse / Pumphouse (14'x6') is highly insulated on a Frost Protected Concrete Slab. Because it is also my Pumphouse and has te 50Gal pressure tank in it, I heat it. I use a recovered Suburban-NT20S RV Furnace ($300 out of a 2 year old wreck, including all hookups, regulator & thermostat) with 2 30LB LPG tanks for fuel. Furnace is only 12V, direct vent and has it's own 12V battery & Solar Panel just for it. I keep the powerhouse at 10C/50F or a little higher but not much.How do you deal with -30C and LiFePo?
