I hope that @Will Prowse doesn't already have intellectual property rights on this subject, but, this is so cool. My new handmade 48v 72ah cylindrical cell battery bank is getting close to 500 cycle ah, and balance between my 12p cells was drifting. at first I thought it was because my balance current was too low for the size of the battery Bank, then I realized that if you are balancing to within 2/1000v, balancing stops when the low cell gets within that tolerance. A low cell never catches up with the higher ones.
Yesterday i got up early before solar charging and shut my power system off... all but the bms. I let the battery sit until voltage stabilized, then i manually balanced the cells by hand with 10ohm electronic resistors... This took a while....???... Then, i figured i should just manually balance the pack through the entire charge and I gave the 2 lowest voltage cells a slight advantage over the other 14 that were all nearly perfect for each other.
My #1 cell had the lowest voltage with a cell diff of up to .015 of top cell after nightly discarge at 50% DOD. Now, it is amazing to watch discharge as the #1 cell is highest right up to a moment before it drops 1/1000v. The other 15 cells fall like dominos after that with the last one being cell #16, then #1 is highest voltage cell again... And in case you didn't guess, cell #16 was the other unbalaced cell.
