I have been kicking around ideas for a tiny (maybe even a nit) solar project, and was looking for ideas/suggestions. We have a chicken coop on the property, and I put in an automatic door opener, which has been working fine. It runs off of a 6v lantern style battery which typically lasts just under a year. Most recently I put a 6v AGM LA lantern battery in. I had been charging it every 5-6 months with an AC charger but this seems like a perfect situation for adding a tiny PV panel to keep the battery charged.
What I was thinking of was a tiny (like 1W or less), flexible, stick on PV panel. I thought they made nominal 12v ones. I would put a diode in line with it, to prevent it draining the batt at night. And was thinking that between the diode voltage drop running a 12v nominal panel into a 6v batt would be fine, not ideal power xfer, but I am really only trying to keep the AGM batt charged. My thought (hope) was that I could do without a charge controller, as long as the PV output was low enough that it would not overcharge the batt.
My question is does this sound like a workable idea? How low an input current would it need to not overcharge the batt? And idea ideas/suggestions for a suitable tiny PV panel?
Thanks
Thanks
