I have a 16cell 48V 280ah battery that is connected to a Growatt SPF 6000T DVM controller/charger/inverter. I've been working with a VNSZNR (Daly knockoff) 16S 200A "smart" BMS with balance charging. I've been tweaking that relationship for weeks trying to achieve a reliable 24/7/365 power source for a 240V 2HP well pump. After weeks of trying to fine tune the parameters on both components, I failed to achieve anything resembling reliability. The cell readings from the BMS were constantly spastic and the charge/discharge status was sketchy with wild swings every second. After a TOTAL of16 charge/discharge cycles the BMS went belly up yesterday. Dead as a doornail. Not a milliwatt of output allowed to flow to the inverter. So.... I bypassed it. Now the Growatt is directly wired to the battery and it's doing exactly what I've been trying to do for several weeks. I have an active balancer that I haven't installed yet and as fate would have it the wiring harness from the BMS is a perfect match to it. I am very tempted to replace the BMS with the balancer and call it system, WITHOUT a BMS. The Growatt is loaded with trip wires to protect the battery and itself from shorts, overvoltage, undervoltage, etc.. Nearly all of them are editable to taste. The active balancer is Bluetooth compliant, and I can monitor the individual cell status with the same Smart BMS application I've been using to tweak and monitor the recently departed BMS. Please explain WHY a BMS would be indispensable to this system. I can't see it as anything but a neurotic kill switch on the Growatt that significantly reduces the reliability of the system.
