learning all the time
- Nov 8, 2019
- 145
Ok long explanation. I have a 25 ft motorhome. I just upgraded to 560AH LifePo4 batteries from Shenzen. I have an Overkill BMS hooked up to the system. I had shore power with a generator via transfer switch. I had a 2000w renogy inverter with two outlets plugged into it and 500w of solar. Everything was working fine and dandy. I upgraded to a Samlex Evo 3012 so all equipment would be able to power up either battery, shore or generator power. I am not beating my system down by running the AC or any high draw system.
Here is the problem: While hooked up to shore power the Overkill BMS keeps shutting down one of the cells for overcharge reasons. That cell gets to 3.65 while the others are at 3.43. It starts balancing then charging then cut off and repeat. While it does this it is causing my coach power to turn on and off. I have the fuse from the converter battery charger pulled as it is a stock converter and does not charge LifePo4 correctly. It is my understanding the converter should take over 12v duties and the battery should just charge. But when the BMS turns on and off my power turns on and off. Without the BMS I do not get the fluctuations with power.
I am tempted to remove the BMS but do not want to destroy the batteries. I read an article here that said it would be OK but then a lot of contradictory replies and responses. Has anyone had this issue or an issue like this? Is there a way to bypass this? I am truly at a loss why the battery charge is creating a fluction in power consumption. Please help.
