Barbuda Cottages
- Mar 24, 2020
- 21
I'm finally receiving my shipment of 160 x Eve 280AH cells that I purchased from Amy. It took 3 months to get from China to Miami, Miami to Antigua, then Antigua to Barbuda and they are arriving on the cargo boat today !
I've been doing a lot of research on top balancing but I'm not finding a lot of information on balancing a large bank ( 160 cells ) fairly quickly . These cells are replacing a worn out set of AGM batteries that can no longer hold a charge so trying to get these new cells in service as quickly and safely as possible is priority as we are fully off grid and currently need to run a generator 12 hours a day to supplement power .
My thought is to connect 10 sets of 16S as they will eventually be and let the outback system ( solar and gen ) charge them up to full 58.4 volts ? Should I connect the BMS's for the first charge ? The outback system will increase voltage and decrease amperage as the batteries become full . Then pull them apart and connect in parallel , maybe sets of 32 and use a 10amp bench top power supply to finish the balance . I bought 2 power supplies so I could do 64 at a time . or should I just connect 2 sets of 80 and wait for the 2 sets to balance ?
My goal is to try to balance quickly so any suggestions would be appreciated .
