Top Balancing woes.
DerpsyDoodler
Photon Sorcerer
Back in Parallel. Slowly creeping up the voltage. 8.2amps going in with a hobby charger.
what's the spec sheet say about charge completion? for lishen, (iirc) when current drops to 8 amps @ 3.65v the charge is complete.
LVLAaron
NOMINAL VOLTAGE: 3.2V
CAPACITY: 100ah (105ah+ is being reported by customers)
WATT HOURS: 320
FULLY CHARGED VOLTAGE: 3.65V
FULLY DISCHARGED VOLTAGE: 2.5V
MAX CONTINUOUS CHARGE: 100A (1C)
MAX CONTINUOUS DISCHARGE: 100A (1C)
MAX PULSE DISCHARGE (10 SECONDS): 200A (2C)
MODULE WEIGHT: 6.5 lbs
MODULE DIMENSION: 7" X 5.5" X 3"
I'm @ 8 amps charging around 3.36 volts. It's only a 10amp charger, so it's just a limitation of the small turnigy
DerpsyDoodler
Photon Sorcerer
i was able to pump ~9.75a in with my little 10a supply. I used thick (10 awg) wire with ring terminals for connection both to supply and battery. You can probably forgo the overkill 10awg but ring terminals are almost necessary.
LVLAaron
I built a new charge lead with some ring terms on it and the charger immediately started pushing 10 amps instead of 8.2.
Nice. Didn't think it would make much difference at this low voltage.
DerpsyDoodler
Photon Sorcerer
i think lower voltages will acually make it more apparent, though let an EE confirm or deny that.
LVLAaron
You get a few more style points and maybe some level-of-difficulty points if you charge your AGM with solar.
... hmmm, maybe watching too much Olympics?
Heh, No solar easily accessible from the shop I'm working out of.
DerpsyDoodler
Photon Sorcerer
How's solar charging agm any more difficult than lifepo4? let alone top balance charging diy cells? ;p
LVLAaron
Ha. We'll see what I can fit on the roof of the camper. It's a curved top so I might have to go with two flex panels
MisterSandals
Participation Medalist
Silicon Valley
How curved? What's your rig? I'd bet someone hear has done it...
I cannot say I would recommend flex panels. They don't have a good record for reliability or production. And there are quite a few issues with mounting them that deals with heat and wind.
