Hi all looking for some help please
My TriStar PWM won't switch into float mode out absorption
System 2.5kwh of PV, 48v system , 330amps of AGM batteries (15kw~), victron shunt
Everything has been working fine , but I recently changed inverter to a new cheap 5.5kw Hybrid and have been using mains electricity to recharge the batteries...
when both tristar and hybrid were being used together I noticed that batteries were holding 14.4v~ even though batteries were 100%soc and had been for hours
on further investigation the tristar was the culprit, I figured it just wasn't playing well with another charge source .
But now I've switched the hybrid off it's been a few hours and the Tristar still won't switch to float , still holding 57.4v (14.35v) and 0.2amp current
Led indicators on tristar say it's in absorption mode , dip switches seem to be correctly set to 14.15v
any ideas on what's going ? All help appreciated thank you
