ilithium1978
- Nov 6, 2020
- 7
Hello to everybody!
I have two solar arrays that will have to charge a 100AH lithium battery (LifePo4), before i was just using a cheap 30A PWM to charge 100AH lead acid battery so things were more simple.
I have configured the settings in Epever Tracer 30A with the add-on of MT50, i have lot of questions also about lithium charge that i will post in another thread.
Is it ok to charge from two different arrays and how should i play with the connections?
I understand that is winter but on a sunny day i will only get about 6-10A and this is about 150W max instead of 400W at least with this setup .. it takes ages to charge the 100AH lithium battery with such low current.
The setup is complicated cause i have some panels (in parallel) on the ground and another array (also parallel) on the roof. Both setup will connect to the same +/- of the MPTT controller.
Array 1 = 3x100 Fuji Fwave 320V that step down to 14.6 and then will go to the EpEver (those panels will give 320V but with step down will go to 14.6 Volt and then deliver to the MPTT)
Array 2= 5x50W 17V panels that will also go to the same +/- EpEver Tracer input for Panels
Some important notes: Charger is 30A maximum but all together will not boost more than 15A now in winter time. Specially the Fuji Fwaves will see not much sun.
Is it ok or is it worse for MPTT that one array is in more shady place and other array will receive more sun?
All of them connected in Parallel .. i plan to play also with the 5.50W in series (Can i have the 3x100W in parallel and somehow increase the current from the other 5x50W in series?)
Maybe should i take out the 320V from the roof for good as they do not seem to product good energy on winter?
Thank you!
Thank you!
