Looking at using terminal blocks pictured below to rebuild two packs, make it a cleaner build. Goal is to have on lead for each battery for both BMS and Balancer to a terminal block then split bms and balancer on other side of terminal block.
Is this a good idea? Want to make sure all the voltages are able to be read correctly by each device and function as expected. I would assume so but want to know if anyone else has gone down this path.
