kwaichi
Hi everyone, I'm in the UK. What's the best inverter to buy to charge up a Fogstar Energy 15.5kwh overnight for 6 hours on cheap rate (7.5p per kwh on Octopus Intelligent Go) while I charge up one of my EV cars which draws 30amps. I have 100amp max to use when car stops charging. overnight amp draw from the house is minimal. My electrician is fine to hook up any all in one inverter and as I'm not exporting back to grid and I'd prefer something that can draw 5kw-6kw peak for battery usage. I'm after something that is smart enough to determine how much ampage is left out of my 100amp to take as much electricity as possible from the grid. My DNO is UK power. A bonus is if it is on the G99 list with an export limiter built into the inverter for when I go on holiday to sell back to the grid at 15p per kwh. Any help welcome!
