50ShadesOfDirt
- Jan 8, 2021
- 437
Having purchased two (SOK) 12v100Ah for various testing projects, I can report that these batteries are working well, as an LFP. Now to manage them ... bummer ... no matter how close I hold my smartphone to them, I can't get any details.
Apparently, commerical vendors are utilizing non-manageable BMSs (inexpensive?) inside each, meaning, I'll never be able to monitor them with any software tools; BattleBorn could be the exception? I've suggested to SOK that the BMS be "upgraded" to manageable, and I'd happily pay the premium for it ... got back a "no"; asking for an "upgrade kit" (what they would want me to use in their product), brought no joy either. I'm on my own ...
The project, then, is to open up the SOK 12v100Ah model, and see if I can get an OverKill in it myself ...
Assumptions:
- the battery will be easy to open up (won't be an entirely sealed ABS plastic case)
- the BMS form will be easy to replace
- OverKill 4S BMS will work in this thing
Progress:
1. successfully voided the warranty on the SOK ... it opened right up (cudos to SOK)
- can't yet identify the BMS, so need more disassembly; it looks like an OverKill will fit right into the same spot as the vendor's bms
- researching the order of cable disconnect sequence, so nobody dies.
2. by the pics, it looks like an OverKill will fit right into the same spot as the vendor's bms
- at this point, I think it's worthwhile to commit an OverKill 4S bms order
Questions ... Questions needing answers ...
The project looks reasonable so far ... no showstoppers making an appearance yet. Anyone see an obvious reason why this wouldn't work?
Assumptions:
Progress:
- will the SOK's metal case block OverKill comms in any way ...
- is there currently a better BMS (for management information) than OverKill (which I think is a JBD variant?)
