boarder2k7
- May 29, 2022
- 59
I just picked up two no name brand 15s server rack batteries as detailed here.
One of them (possibly both) needs a new BMS. I'm finding that options for 15s BMSes look relatively slim when thinking about overall features and compatibility with other packs in the future as most good server racks seem to be 16s setups. I really like the looks of the Overkill BMS but it is 16s only.
Is there any reason that I can't grab myself two new 100 Ah Eve cells, top balance the whole lot, and drop the Eve cells in line with the existing 15s setup to get a 16s that could use a better BMS?
I understand that the new cell would likely be a higher capacity than the rest of the pack that has had some cycling (unknown count) up until this point, but in my understanding as long as they are top balanced, I'll still be able to get the full capacity out of the original 15 cells. The new 16th will essentially not ever fully discharge.
Is this a viable course of action? Alternatively if someone could recommend a good 15s BMS that has decent communication protocols that I can hopefully monitor from Linux, that would also work.
Thanks in advance for any help. All the threads I found in my search were about putting 15s and 16s in parallel with each other, but no one seems to have touched on doing this.
