Currently have a 10.6kw ground mount system, inverter is a 10k solar edge and uses optimizers. Have 3 Tesla Powerwalls installed in the garage, the array is apx 300' from the main panel.
I would like to add another 4-6k of panels, my inverter will not support that so an additional inverter or two is going to be required.
My question is this, If I add a second "system" and feed the existing sub panel at the array I am assuming since the Tesla Gateway will protect the grid and I would assume that any power coming from the array including battery would be seen as just more power from the existing panels. Same with the batteries, they should just accept any more power that was sent down the line.
Is my thinking realistic?
Thanks John
Thanks John
