USB-C to fuse box?
Yes, why not? get a USB-C power delivery board that can do 100W charging and work with the output voltage of the bluetti
You would need a device with a chip on it that connected to the USBC port and faked it into constantly delivering 12v.
(I believe they're called PD Decoy circuits and they're available @5V, 9V, 12V, plus other USB spec voltages)
Then you could just wire that into your little breakout box and enjoy 12V at about 8A.
Also, can I ask why you specifically want to use the USB C output in this way?
I would like to run a few things off my B230 unit. The fridge will take the cig lighter outlet, then I'd like my 2 MaxxAir fans to be run off this battery, too.
The AC200MAX will be a bit more portable - moved when used with cooking implements, and preferably turned off at night.
