Boondockorbust
- Jun 3, 2020
- 5
I apologise in advance if the title of the thread might not be worded appropriately for the question I have.
I have recently ordered a set of 130AH AL cased cells, and will pair them with the Overkill BMS which has already arrived. I just finished installing a Progressive Dynamics PD9145ALV 45 amp charger/converter. These will be in use on my teardrop camper which already has a renogy Rover and 100w panel.
My question is regarding the ability to maintain the battery at a lower state of charge to increase longevity. I know that I can set custom voltage parameters for the Rover and would be able to keep the battery at something like a 30-70% charge while on solar.
The issue it seems, is that although the converter is meant for lithium, it's goal is to fully charge the battery with no adjustment possible to the values it abides by. I know that the BMS should be able to cut charge and discharge current at levels of my choosing, but I wondered if this might affect the charge adversely if the level ends up not accurate due to charge voltage vs actual etc. Also would the charger possibly be stopped before it entered an important phase of the charge by simply disconnecting via the BMS?
If it ended up that I was best to just set the solar controller as I wanted and whenever I was plugged in I ended up fully charged then I could easily live with that for the sake of simplifying things. I will primarily use the trailer off grid as I move cross country later this year.
