The subject says it all. I was wondering whether anyone has tried connecting a solar panel micro inverter to a battery bank instead of a panel. I'm talking here about the grid connect micro inverters that go straight into 240V and have their own anti islanding protection. Obviously you would need to setup a battery bank that's in the MPPT tracking voltage of the micro inverter (say 36V).
My gut feeling is that is should work, volts are volts. But I was wondering if anyone here had tried.
My thinking is that by switching out a couple of panels in the evening and connecting batteries to the inverters instead, I can shift my solar power into the expensive evening periods. I'm on a wholesale plan, so I usually only need an hour or so of coverage to save several dollars in electricity.
Also I have a pile of old deep cycle batteries to experiment with. So I may as well put them to use.
