ricardocello
Watching and Learning
First, find out what brand you have. Like all hobbies, there are people out there who love this stuff.How would one go about researching their electric meter to see what all it can do?
Depending on your technical prowess:Now I have to figure out how this thing is programmed without garnering unwanted attention.
It is called Emporia Vue Utility Connect.. It requires the utility to register it so that it can read the Zigbee signal. In my case PG&E did not allow those to be used for solar customers with a NEM agreement. Check with your utility. Those devices are called HAN devices and the Emporia is the least expensive and does not require a subscription. Rainforest and others also sell similar devices some of which require a subscription.Which one intercepts the meter's zigbee signal?
What kind of idle draw do the chargeverters have when they are not supplying any current? I was thinking of just hooking up a chargeverter but having it set at a very low voltage, so it would only supply power to the DC circuit when it either dips under heavy load, or the batteries/solar are depleted.@kolek this is kind of what you were alluding to correct?
When the DC circuit gets up to whatever that low voltage is, the chargeverter wouldn't be outputting anything (of any significance) and the solar would resume charging the bank back up when the sun comes back up.
This way I don't have to worry about when to turn it on or off, it would just always be supplying converted AC to DC from the utility as needed.
Around 7w.What kind of idle draw do the chargeverters have when they are not supplying any current?
The fans run all the time? Not temperature controlled?Around 7w.
But the fans will be annoying.
This is why mine is controlled by the dry contacts.
They speed up with more load and/ or temperature.The fans run all the time? Not temperature controlled?
I am not a lineman but of all the videos I have seen of linemen at a break they usually ground the lines at a junction before the work.I would probably follow the standard procedures to check that a line wasn't being backfed when working on it. More things than a grid tied / synced inverter can cause a line to be live in a power outage.
More and more people are getting prebuilt AIO solar generators with batteries in them and using them as UPS's. I would imagine almost every one of those devices is like this growatt and does spurious backfeeding as they are probably using the exact same hardware inside. They are getting bigger and bigger, many of them are up to 3-4k output already.
The power companies aren't concerned about the lineman. They are concerned about their gravy train.
It is.I am not a lineman but of all the videos I have seen of linemen at a break they usually ground the lines at a junction before the work.
Not sure if that is standard practice or not..
Sorry, I wired mine up and tested them one time from my genset to test them and do a test charge to verify they work, but did not test anything else.What kind of idle draw do the chargeverters have when they are not supplying any current? I was thinking of just hooking up a chargeverter but having it set at a very low voltage, so it would only supply power to the DC circuit when it either dips under heavy load, or the batteries/solar are depleted.
EDIT.. answering my own question.. the new Chargeverter claims 10w idle. Couldn't find that spec for the old one.
Your generator, or your gender?Sorry, I wired mine up and tested them one time from my genset to test them and do a test charge to verify they work, but did not test anything else.
My gender is controlled via my magnum inverter
