sunshine_eggo
Happy Breffast!
I've had a hard time locating the actual range of the Prius battery while running/charging. It might go slightly over 250v. The Midnight would still work though as it has that buffer zone protection thing. You would want to cap the amps on the Midnite though. I don't recall what model year he said his Prius is, but the 1st, 2nd and 3rd gen Prius shouldn't be run over 3000watts continuous from the traction battery system according to the Plugout Power guy.
Idle charge is around 5kW. It cycles between about 40% SoC and 47-52% SoC.
It could bust 250V, but it's pretty rare under idle charging, though cold can influence that. With forced charging, you can really get up there... 280V and as much as 20kW (that the power limit on MG1 - almost impossible to get above 16kW).
The plugout power units have 450V MPPT that are attached to the battery.
