jeremyjeremy
- Aug 31, 2020
- 9
Hey Travis, are you saying i could pop off the side panel to access the cell balancer and add in the OVERKILL BMS to these Valence batteries? or is it best to use the Valence BMS?
The Thunderstruck BMS wasn't too expensive. It's super simple and activates the internal BMS on all the batteries in the chain, and includes outputs for high/low voltage contactors. If you have more than a few batteries you might want the more expensive solution Travis can put together.
