LithiumSolar
- Nov 19, 2019
- 184
The cell voltage should NEVER EVER go over 3.650 !!!!!!!!!!!!!!!!
3.65 x 16 = 58.4 V Battery Pac total. That is still high but anything over this is insane...
Use the overkill Solar app and you can select the 16 cell default. I typed in Off Grid Garage settings with a little tweeking. Quick fix but they must not have even programed the BMS when they put it together. No complaints now I reprogrammed it.
WARNING TO ALL WHO HAVE BOUGHT THIS BATTERY, CHECK BMS SETTINGS
Really? You seem quite serious there with your "NEVER EVER go over 3.650 !!!!!!!!!!!!!!!!"
GFB recommends the following in their datasheet (I know Vatrer isn't using GFB, but just using this as an example). We could debate whether or not we have a way to satisfy 5.6.1 as it sounds like that would require communication with the charger, but their over-charge volt setting of 3.75V is less than what others are suggesting of 3.80V. Remember, these are safety settings, not charge control settings. Your charger should be programmed with the correct voltages to avoid hitting these conditions.
![Screenshot_3.jpg Screenshot_3.jpg](https://diysolarforum.com/data/attachments/229/229984-a3a10cdbf0335fc5312f0e0b21bf96c3.jpg)
Just my two cents...
