Brucey
Solar Wizard
Not too shabby, now the decline towards winter as we pass the equinox.The total solar power generated so far today is 98.2 kWh.
I hope to have the last array done before the winter. I also need to get one more Victron, which is most likely a 450/100. I just checked usage again. The total usage is 96.1kWh, and PV production is 131.4kWh. I'm impressed with the EG4s. They have a smaller number of arrays but did 65.4kWh of PV.Not too shabby, now the decline towards winter as we pass the equinox.
How many KW panels do you have now? I know you've mentioned it but can't remember.I hope to have the last array done before the winter. I also need to get one more Victron, which is most likely a 450/100. I just checked usage again. The total usage is 96.1kWh, and PV production is 131.4kWh. I'm impressed with the EG4s. They have a smaller number of arrays but did 65.4kWh of PV.
Considering my current array size, those numbers are great. It would be interesting to see what it can do if we get some extended cloudy days and the banks get down to 60% or less. We are in float almost every day between 12:00 and 1:00 p.m. across all banks.How many KW panels do you have now? I know you've mentioned it, but I can't remember.
Your 1 day total is ~ my 3 day total with 10.85KW of panels, I'm impressed.
Sounds like an amazing setup in the end. ~ 1,400A of DC charging in ideal conditions, damn.Considering my current array size, those numbers are great. It would be interesting to see what it can do if we get some extended cloudy days and the banks get down to 60% or less. We are in float almost every day between 12:00 and 1:00 p.m. across all banks.
70 Znshine and Trinia. I need to check on the exact watts, but the difference between them was like 5w so roughly 35,350w
35 Canadian bifacial rated at 520w. - 18,200
30 Canadian 455w - 13,650
It's roughly 67,200w at the moment. I have one more pallet to install, which is another 30 of the non-bifacial 455w. So, I should be around 80kw in the end.
We definitely have plenty of mppts, but based on prior amps, I'm curious to see what it can do. Before all the changes running on 8 growatts, the max I have seen was just over 500 amps with the banks around 50%. Today, with the two banks at 93%, it was around 340 amps which is decent considering the soc. Bank two was already in float so I was not able to see what it was doing.Sounds like an amazing setup in the end. ~ 1,400A of DC charging in ideal conditions, damn.![]()
Is that near a record for production? Do you plan to add more panels?Got some cloud edge effect today, got a crazy max of 6854W or nearly 125A albeit momentarily.
Isn't there an app on your phone that lets you look at these numbers (to take screenshots with the power button + volume) , instead of taking a picture of a screen?I got the second neey in and slowly increased the voltage on the new bank's top and bottom. They worked perfectly, staying within .009 going up and finally down to .001. The camera did not want to focus on the screens.
Yeah new record at least for max output. Added an inverter window ac unit that's added about 500W more in load so expecting actual daily production to be about double going forward.Is that near a record for production? Do you plan to add more panels?
Most of my posts consist of screenshots from my phone and PC. But I did not want to touch the phone or tablet since this was my first time bringing these banks past 3.4v.Isn't there an app on your phone that lets you look at these numbers (to take screenshots with the power button + volume) , instead of taking a picture of a screen?
Tell her getting a second job will really help with the solar. If you can convince her, let me know how you did it, and I will try it.Yeah new record at least for max output. Added an inverter window ac unit that's added about 500W more in load so expecting actual daily production to be about double going forward.
I would consider this 450/100 to be fully utilized, actually I'll have to remove one panel before winter or I'll be over 450. Planning on a second one soon. Wife has given green light for expansions not that I needed it but her blessing is always less internal stress.
I have the lawn mowing part time business, now when I mow I'm thinking this yard is worth 1 280Ah cell, or I generated four cells of revenue for the day etcTell her getting a second job will really help with the solar. If you can convince her, let me know how you did it, and I will try it.
