Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,844
Victron video: How to not blow up your Alternator when charging Lithium.
Unless you're driving a steady speed down the freeway, plenty of low speed operation is eventually going to occur - That's why the used of a DC to DC charger is so highly recommendedPlenty of people let their engine idle with a high load on the alternator (bad).
It does show that manufacturers should have temperature derating of alternators from factory.
Provided there is a reasonable amount of resistance in the feed to the lithium battery to keep the current at acceptable levels and you are able to monitor the process, I would think there would be no issues.is it okay to run my alternator directly to the lithiums for short periods of time.
The issue was discussed in depth here."Provided there is a reasonable amount of resistance in the feed to the lithium battery to keep the current at acceptable levels". Can you tell me what that means please.
That really didn't clear things up for me very much. I'm getting the impression that internal resistance goes down with the soc. So charging directly from the alternator is less likely to cause problems for either the alternator or the batteries with partially charged batteries. I'm thinking to test this out with the soc between 50 - 80% with me right there watching the monitor and shutting it down once I come to some feeling as to what will actually happen. Specifically interested to see the how the volts and amps compare to what comes through my B2B.
This must be the 10,000th post about charging LFP with an alternator. It's getting old, use the Search function and read up on it.So an alternator puts out xxx amps. And a portion of that goes to run the vehicle. And what's left over should be available to the storage batteries. And that the amps an alternator produces varies with the condition of the alternator. Am I understanding this approximately correctly? The question I'd like to find an answer to is; is there a way to measure how many amps are being used for basic vehicle functions and what is the maximum total the 'my' alternator will generate?
My B2B is 30A. I'm wondering if it's maxing out the alternator to do what it is designed to do. That's why I'm curious about the overhead of my alternator.
